Hybrid DSP 8x100W Class T amplifier
A 10 channels amplifier solution powered by Sigma DSP
8 channels 100W/ch Class T amp + SPDIF out
Perfect for audio folks and testers
If you run out of outputs on your classic stereo amplifier, the solution is right there.
Stereo, Home cinema, test bench... and many more options, fully programmable and stand alone solution.
If you want to use a 4 way stereo equipment or a home cinema set up you can use the 8 channels powering 100W per channel. 2 extra channels in SPDIF are also available to add deported surround or active speakers or whatever you want
All channels are programmable separately from each other via Sigma Studio software.
Adobe Portable Document Format - 9.00 MB - 07/13/2017 at 07:24
Preview
Download
Adobe Portable Document Format - 1.74 MB - 07/13/2017 at 07:24
Preview
Download
Adobe Portable Document Format - 751.09 kB - 07/13/2017 at 07:24
Preview
Download
Adobe Portable Document Format - 298.00 kB - 07/13/2017 at 07:24
Preview
Download
Adobe Portable Document Format - 202.51 kB - 07/13/2017 at 07:24
Preview
Download
View all 8 files
  • 1 × Analog Devices ADAU1452 evaluation board DSP
  • 2 × Sure AA-AB33182 4x100W class T
  • 2 × SMPS MeanWell NES 350-24 Switching power supply 24V - 15A / powering amps
  • 1 × Toroidal transformer 230V to 12V powering rsource selector
  • 1 × Regulated power supply LT1084 5V to 20V powering DSP
View all 19 components
SimpleTech wrote 07/18/2019 at 05:35 point
Last time we used MeanWell SMPS we ended up enducing lots of RF noise due to EMI radiation. They tested to comply at 80% load, any variation causes them to go outside of specs badly.
Work around was to build all PCB's using 4 layer topology, where top and bottom layer where solid copper for shielding, internal 2 layers are tracks. We also used top layer as heatsink for power components as it was 3mm aluminium plate. Had EMS company to prototype PCB's: http://www.papcb.com/flex-pcb/ they do lots of high tech PCB assemblies.
Alternative is to place SMPS's in separate fully enclosed metal casing and also place filters on in/out wiring to cut the noise.
adri1 B wrote 07/24/2017 at 07:29 point
Hi,
Definitely possible, you need to find a dsp board with 12 output channels (like Shark Analog devices or MiniDSP). Sure audio are making 6x100W amplifier boards for nothing in Class D architecture. You just need to combine 2 amp boards and the dsp and you'll have 12 channels dsp amplifier. By the way, Focal and Pioneer are making really good digital amplifiers for car with multiple output and also a good guid for tuning the car. But if you choose an Analog devices dsp you can program at least 1000 biquad for your tuning, so you can make your crossover / peak eq / all pass for time alignment / virtual center / delay / limiters... If you need some advises for car tuning don't hesitate to contact me, i'm acoustical/application engineer, i do a lot of tuning on premium car with this kind of amplifiers. Jut a small question, you're not using a subwoofer and center for your application ? in this case you can drive 2channels in doors (woofer + passive mid/tweeter) + 1 channel as center + up to 3 coils subwoofer with the last 3 channels
mbt28 wrote 07/20/2017 at 14:22 point
Hi,
I was making research for while for this amplifiers. However I would like to drive 12 speakers instead of 8, is it possible. I would like to build one as digital car amplifier. so each door has 3 speakers in total 12 speakers. Is it possible set freuquencies for each speaker in this setup?
Thanks
