• 1
    Whats in the Box?
    Whats in the Box?
    Step 1: Parts in the box
    • GPS Antenna
    • 1 4G antenna,
    • 1 3G antenna.
    • USB cable to connect to the Raspberry Pi.
  • 2
    Put PiAnywhere Together With the Raspberry Pi
    • Raspberry Pi wall plug Into Pianywhere to power both Pianywhere and Raspberry Pi. ( You don't need to also plug in the rasberry Pi.
    • Put the 2 antennas and the GPS antenna into Pianywhere.
    • Sim card into the PiAnywhere (which you can buy from any major sim provider )
    • USB into the modem to connect to the Raspberry Pi.
  • 3
    Setting Up the Raspberry Pi
    Components needed for the Raspberry Pi to be operational:
    • Raspberry Pi 2 or 3.
    • Monitor.
    • Mouse and keyboard.
    • HDMI Cable.
    • Raspberry Pi Charger.
    • SD card (more than 8GB is required) with the latest version of Raspbian Jessie.
    The guide to setup the Raspberry Pi software can be found at https://www.raspberrypi.org/learning/hardware-guide/
    The latest version of the Raspbian Jessie can be found at https://www.raspberrypi.org/downloads/
