Getting the right voltage
A project log for Arduino Pro-Mini RC and servo mesh shield
An arduino pro-mini shield for the nrf24l01 smd with servo outputs
adamcadamc 07/22/2017 at 14:100 Comments
Voltage Issues
One of the hassles with this and the Arduino is that the arduino is 5V and the nRF runs at 3.3v . There are a few carriers out there, but i wanted something really small and easy. So I'm using the voltage drop across a LED to power this. You'll need one of the normal size LED's and they drop just under 2v and also provide a visible indicator as it will pulse as the nRF goes about its business.
