Bottom part almost done and legs attached
A project log for 8 legged spider robot
This robot uses only 4 linear micro servo’s, an arduino nano, a bluetooth transeiver two lipo battery's in order for it to work.
brian-brockenBrian Brocken 07/26/2017 at 19:230 Comments
the bottom part is almost done. I just have to place and connect the servo’s. I also attached the legs to see if it would work and they do support the body but just. So I probably going to design some new smaller and higher legs that hopfully do the job.
