10 units
A project log for Numitron Hexadecimal display module
Another hexadecimal display, this one is sans transistor for the extra vintage touch, and uses only Soviet-era parts
yann-guidon-ygdesYann Guidon / YGDES 08/16/2018 at 01:352 Comments
I soldered the 10 PCB :-)
The modules work great. I've had only 2 parts wrongly soldered (one reversed diode and one reversed relay) but they were easy to spot.
The IV-9 are soldered with "loose" pins so they can be adjusted for later mounting.
All these modules, as well as the 5 pre-series, will be used for the #Hardware assembler / EMUI of the #YGREC8 :-)
alice crush wrote 10/24/2020 at 00:14 point
woohoo! what fun to read your logs!
Yann Guidon / YGDES wrote 10/24/2020 at 16:06 point
Thank you !
And I hope it helps you as well :-)
I hope the "bipolar diode ROM" trick will be reused by others, such as maybe a microcode ROM.
I have reused this technique almost verbatim to drive the #YGREC8's "disassembler display":
https://hackaday.io/project/27280-ygrec8/log/170273-condition-codes-decoder-display
https://hackaday.io/project/27280-ygrec8/log/170269-register-name-display-ok
