Release 0.2.0: improved Data Log, better Sensor Filtering
A project log for W1209 Data Logging Thermostat
The W1209 thermostat is cheap, but it's about time that it learns new tricks!
thomasThomas 12/17/2017 at 10:240 Comments
I've just release a new, improved version of the W1209 Data Logging Thermostat: now the data logger registers the following data:
Used properly, this data can be used to improve the control behavior (heating power), or for getting clues on the effects of heat flow & thermal mass, sensor location, or quality of the insulation:
w1209-log2Check out the README on Github for features, source, and instructions!
