• First Update
    Mr. Spriggs08/07/2017 at 06:59 0 comments
    I have finished the first prototypes. Now is the time to share. The boards work great charging and the buck booster keeps the Pi running smoothly. Now it is time to focus on the software side. The MAX17043 has no real software to run on the Pi. I used some examples and did a lot of  simple serial test with an Arduino. Nothing has been done to use the Pi to monitor the battery.
