Arduino Pro Micro + sigrok-cli + PulseView
A project log for GinLogic | Arduino DUE, UNO | GinLab
Logic Analyzers with Arduino
gintaras-valatkaGintaras Valatka 09/21/2017 at 16:550 Comments
 * Arduino code for 8 pin analyzer
 * Due/Pro Micro can be Serial.begin(0);
void setup() {
  Serial.begin(0); // <-- Add required speed like 2000000
  while (!Serial) ;
  Serial.println("Connected");
void loop() {
  Serial.write(PIND);
 * Run sigrok-cli
sigrok-cli -i /dev/cu.usbmodem411 -I binary -O ascii --continuous
Can add more params like '--config samplerate=9600' <--- set the speed
Dump raw data and import it into PulseView https://sigrok.org/wiki/PulseView
dd if=/dev/cu.usbmodem411 of=./raw bs=1 count=1m
The above can be achieved by counting 0-255
Broken USB, homeless, no more testing... :( Lewisham Council making me sleep rough
