Coin cell battery emulator CR2016/CR2032
Disappointed purchasing new batteries for development?
Do you need measure current and consumption of your device?
This simple hack save planet :D or maybe your wallet ....
- It is just small round piece of board
- micro USB for delivery power
- 3V regulator
- alligator clip holes for your multimeter to measure curent
- single board with micro usb is CR2016 =1.6mm + adapter is CR2032 = 3.2mm ... EASY ?????I
understand is not like real CR2032 but I believe that help with development battery operated devices.
[deleted]
bobricius wrote 06/19/2018 at 19:54 point
K.C. Lee wrote 06/19/2018 at 20:09 point
You'll need to think beyond Joule thief as it isn't practical for that kind of wattage nor that voltage.
I am working on my project, but don't think it would deliver 4W.  I am guessing 0.5W (or may be a bit higher) might be a realistic number.  I don't have the answer until I try.  0.5V is not an easy voltage to work with as most common parts do not work on that natively.
https://hackaday.io/project/158839-boost-converter-for-low-voltage
[deleted]
bobricius wrote 06/19/2018 at 19:55 point
It is ML2032
C. Dodd wrote 09/19/2017 at 03:23 point
I agree with Marian (above).  Resistance of coin cells is something integral to several circuits.
Also, the Tindie price is quite high for such a simple board.
oshpark wrote 09/18/2017 at 18:52 point
Great idea!
deʃhipu wrote 09/13/2017 at 12:45 point
I think you just invented a pretty interesting connector in there...
bobricius wrote 09/13/2017 at 12:49 point
lollipop :D
Marian Keller wrote 08/22/2017 at 09:08 point
Now make the output voltage adjustable and add an adjustable series resistance, and this would be really helpful in development.
