Bluetooth Low Energy Controlled Tank
Use your phone as a remote controller for a Raspberry Pi controlled chassis
turrent.stl
This was designed by khaine 238 at TickerCad: https://www.tinkercad.com/things/7mmD4zDsU6Q-gothic-tank-turret
Standard Tesselated Geometry - 236.90 kB - 08/22/2017 at 14:39
Download
View all 11 components
  • Video
    Quintin Balsdon09/27/2017 at 13:18 0 comments
    I have uploaded a video of the tank to YouTube! Enjoy!
  • The Project
    Quintin Balsdon08/22/2017 at 14:34 0 comments
    This project was done in a bit of a rush. I was already working on a Bluetooth Low Energy peripheral device using the Raspberry Pi when I heard a co-worker was leaving. I had the peripheral working as a kind of "remote command line" - I can send the NodeJS BLE peripheral short-lived terminal commands and send the result back to the phone via a notification.
    So I added a new characteristic: A motor controller that the Android device can send a message in order to run motors at a specific speed. Then it was just about building the bot.
View all 2 project logs
  • 1
    Set up your Pi
    Install NOOBS on the SD card and get logged into your Raspberry Pi. Install the prerequisites:
    sudo apt-get update
    sudo apt-get install npm pigpio
  • 2
    Get the code set up
    1. cd ~
    2. sudo mkdir repo
    3. cd repo
    4. git clone -b feature/ble_tank https://github.com/qbalsdon/BLE_Rpi_Peripheral.git
    5. cd BLE_Rpi_Peripheral
    6. sudo /scripts/setup.sh
  • 3
    Connect all the pieces together for a test
View all 3 instructions
