5-bar linkage model is designed and tested
A project log for Post Stroke Spasticity Rehab Helper
The spasticity is the most common post stroke effect. We construct simple open sourse Arduino -based Post Stroke Spasticity Rehab Helper.
sergei-v-bogdanovSergei V. Bogdanov 08/31/2017 at 11:260 Comments
The driving gear for a massage of fingers was constructed and tested. We choose 5-bar linkage with 2 servos. Here is the assembled construction and components. The lever arms  and bases are made from FR4 Blank Clad Circuit Board using micromiller, or it can be 3D-printed.
We made model linkage to calculate the angle values. We use simple test program to controle servos by potentiometers to find the angles for movement.
