Things used in the project:
Hardware components:
  1. Arduino UNO & Genuino UNO × 1
  2. DFRobot's 2.8" TFT Touch Shield × 1
Software apps and online services:
  1. Arduino IDE
  2. DFRobot Image Converter
Hand tools and fabrication machines:
  1. Stylus (generic)
The Specifications
Pinout
Pin Definitions
TFT, Touch, SD-Card and external flash memory pin mapping
Bubble Display
Graphic Display Example
In the sketch -
tft.drawString(5, 10, "Romantic cabin");
tft.drawLine(x, y, x-80, y+30, YELLOW );
tft.drawRectangle(x-40, y+50,x-20, y+70, 0x8418);
tft.fillCircle(x+100, y-30, 20, RED );
The Drawing Board
We can make a home made digital drawing board in just a few minutes. All we need are Arduino and this TFT shield.
How :
In the sketch -
dmTouch.readTouchData(x, y, touched);
The syntax is :
<object_name>.fillCircle(x ,y, <point thickness>, <point color>);
Moreover, you can draw on it and to clear it, use the reset button on the screen to clear the graphics.
Display a pictures from a SD card
It requires a special format for the displaying picture: 16bit RGBRGB bmp.
You could download the convert tool here: ImageConverter
Why 16 bit, not 24 bit?
There are 2 reasons for converting your images to 16-bit bmp with flipped row order:
a) The MCU does not need to convert the 24-bit to 16-bit 565, this is already done.
b) If the source format is already in correct order, a faster algorithm for reading the data can be used.
c) There is less data to read (because the image is only 2/3 of an original size)
Compared to raw picture data, there are several advantages:
a) It has meta data about the format, size, how it is stored etc. With raw data, the program must already know this.
b) It is a standard so it can be viewed directly in most viewer (although not all viewer )
c) Can create and edit the images in advanced photo editing programs like photoshop.
Anyway, there is converted picture in the library folder (DmTftLibrary\examples\DM-TFT28-105). You could have a try with it first.
1. Copy the converted picture to the SD. 2.Plug SD card in the touch screen. 3.Upload the sketch given in the attachments.
Note : Install the SPIFlash library before you compile the sketch. Click here to download it form the GitHub.
Buy the shield from DFRobot.com now.
