Repository and License
A project log for Trinket Shields
Add-on boards for the Adafruit Trinket M0.
dehipudeʃhipu 09/22/2017 at 09:212 Comments
I have put all the shields I made so far in one repository at https://bitbucket.org/thesheep/trinket/src and also added a license, the usual CC BY-SA. You will need to install Fritzing to open the files and generate gerbers from them.
There also @oshpark links, so that you can order the PCBs from them:
Paul NeoStormer wrote 10/31/2019 at 02:47 point
Are these the most up to date versions of all the shields?
deʃhipu wrote 10/31/2019 at 08:52 point
Well, no. But these are the most up to date that have been published.
