So far, I have been able to get the car to move on the track that I have designed and this month I moved onto the hardware side. I attached a photoelectric sensor to an Arduino to measure the speed of the user pedaling and convert the data I receive into the speed. I also continued to research on how to transmit this data into unity and found out that I need to use the serial port for that and I started to configure this.
