I worked further on the Unity code and learned about how to place objects in the scenery and adjust their position and size. I also started to work on shaders and lighting in the game. I looked at different sources to better understand how to implement Arduino and Unity such as: https://www.alanzucconi.com/2015/10/07/how-to-integrate-arduino-with-unity/. I also continued to look at different research articles such as: https://www.ethz.ch/content/dam/ethz/special-interest/baug/ivt/ivt-dam/vpl/reports/1201-1300/ab1244.pdf. The article also brought up other concerns such as smoothing the data received from the sensor and possible filtering methods.
