Can I use X sensor?
A project log for CarbOnBal
Arduino based carburetor and throttle body balancer / synchronizer
dennisdennis 02/16/2020 at 18:073 Comments
I just got an interesting question.
Can I use X sensor?
The answer depends on three basic properties;
1  you need a 1 Bar sensor for best accuracy
2 it must operate at 5V and produce a voltage swinging from as low as possible to as close as possible to 5V for ultimate accuracy.
3 It needs a 3 pin connector (5V, Ground, signal (in any order, as long as you know which pin goes where)
We are really looking for a MAP sensor that was designed to work at 1BAR. That means it was originally intended for use in a vehicle without a turbo! This is important because a turbo sensor may go up to three Bar or more and we only need to measure the carburettor or throttle body vacuum (the values below 1 Bar). Going to three reduces the accuracy by a factor of 3 (almost). It would still work and probably still be accurate enough for a decent tune-up, but insane accuracy is one of the main attractions of CarbOnBal!
It needs to be powered by 5V because that is what our Arduino works with, using a 3.3V sensor would require an extra power supply and a voltage reference, that is more external components and a few lines of programming. It can be done but I can't support stuff I can't test myself.
There are some crazy sensor designs out there with many pins. I have no idea how to hook them up, and they probably require more external components to use. Stay away from these at all costs. There could be designs that are usable, but you are on your own if you decide to use one of those units.
dennis wrote 03/02/2020 at 15:00 point
The two parts recommended in the parts list are the ones I have verified from their respective datasheets, and later in practice by several project builders. Of course there are a lot more floating around that would be more or less suitable, but, as you found out, the documentation is mostly lacking.
Walt wrote 02/17/2020 at 06:54 point
Here is a list based on google searches and sales that are rated at 1 bar and are all interchangeable.  Prices run from $4.49 to $37.04 and beyond.
213259
213351
213351
213361
213796
216451
5S1153
5S2398
2134434
7472328
09359409
1580750
9359409
16212460
12575837
12614970
12614973
16187556
16249939
19236265
21024034
62630045
89052738
8093594090
8162124600
8162499390
8126149700
8126149730
8161875560
213-259
213-351
213-361
213-796
213-4434
AS60
EC1636
EC1686
MP103
PS1000011B1
PS10002
PS10000-11B1
SU1176
Walt wrote 02/16/2020 at 21:19 point
This is good to know about getting the correct bar and voltage rated sensor. How do you determine the bar and the voltage rating? I have found a lot of sensors on Amazon and Ebay but those ratings are not shown. Are there certain part numbers you have worked with that you know are the correct ratings?
