Control Board FPGA Pinout
A project log for BARCO NX-4 GROUP REVERSING ADVENTURE
This a project for a group of folks working to reverse engineer the Barco NX-4 LED panels.
moddermikemodder_mike 10/27/2017 at 07:480 Comments
I might be missing a few connections yet which I'll correct as I come across them, but here is the pinout of the XC3S250E FPGA on the control board.  Note that the SRAM and the Flash share an interface bus.  Also note that the JTAG interface is 2.5V logic.
PinFunction PinFunction
1PROG_B (Pullup to +2.5V)73GND
2LED_L1_SIN74SRAM_A16; FLASH_A15
3LED_L2_SIN75SRAM_A15; FLASH_A14
4LED_L3_SIN76SRAM_A14; FLASH_A13
5LED_R1_SIN77SRAM_A13; FLASH_A12
678
7LED_R2_SIN79VCCO_1 (+3.3V)
8LED_R3_SIN80VCCINT (+1.2V)
9VCCINT (+1.2V)81SRAM_A12; FLASH_A11
10LED_XERR82SRAM_A11; FLASH_A10
11GND83FLASH_RESET#
12
84
13VCCO_3 (+3.3V)85SRAM_A10; FLASH_A9
14LED_L4_SIN86SRAM_A9; FLASH_A8
15LED_L5_SIN87SRAM_A8; FLASH_A7
16LED_L6_SIN88SRAM_A7; FLASH_A6
17LED_R4_SIN89
1890GND
19GND91SRAM_A6; FLASH_A5
20LED_R5_SIN92SRAM_A5; FLASH_A4
21LED_R6_SIN93SRAM_A4; FLASH_A3
22LED_CAL_SIN94SRAM_A3; FLASH_A2
23CPLD_PIN_4495
24CPLD_PIN_696SRAM_A2; FLASH_A1
25I2C_SCL97SRAM_A1; FLASH_A0
26I2C_SDA98SRAM_A0; FLASH_DQ15/A-1
27GND99GND
28VCCO_3 (+3.3V)100VCCO_1 (+3.3V)
29101
30VCCAUX (+2.5V)102VCCAUX (+2.5V)
31SRAM_CE#103SRAM_WE#; FLASH_WE#
32LED_XLAT104FLASH_CE#
33LED_MODE105FLASH_OE#
34LED_BLANK106
35SRAM_OE#107FLASH_RY/BY#
36108JTAG_TMS
37GND109JTAG_TDO
38110JTAG_TCK
39LT1933_ENABLE111FAN_TACHOMETER
40112INPUT_CONN_PIN_5
41113INPUT_CONN_PIN_4
42VCCO_2 (+3.3V)114
43SRAM_BHE#115VCCINT (+1.2V)
44SRAM_BLE#116INPUT_CONN_PIN_7
45VCCINT (+1.2V)117INPUT_CONN_PIN_2
46GND118GND
47119INPUT_CONN_PIN_8
48120INPUT_CONN_PIN_3
49VCCO_2 (+3.3V)121VCCO_0 (+2.5V)
50SRAM_IO7; SRAM_IO15; FLASH_DQ7122
51SRAM_IO6; SRAM_IO14; FLASH_DQ6123CPLD_PIN_8
52SRAM_IO5; SRAM_IO13; FLASH_DQ5124CPLD_PIN_3
53SRAM_IO4; SRAM_IO12; FLASH_DQ4125CPLD_PIN_2
54SRAM_IO3; SRAM_IO11; FLASH_DQ3126CPLD_PIN_5
55GND127GND
56OSC_40MHz128OUTPUT_CONN_PIN_5
57129OUTPUT_CONN_PIN_8
58SRAM_IO2; SRAM_IO10; FLASH_DQ2130OUTPUT_CONN_PIN_7
59SRAM_IO1; SRAM_IO9; FLASH_DQ1131OUTPUT_CONN_PIN_4
60DIAGNOSTIC_LED_YELLOW132CPLD_PIN_43
61GND133GND
62DIAGNOSTIC_LED_RED134OUTPUT_CONN_PIN_3
63SRAM_IO0; SRAM_IO8; FLASH_DQ0135OUTPUT_CONN_PIN_6
64VCCO_2 (+3.3V)136
65VCCAUX (+2.5V)137VCCAUX (+2.5V)
66FLASH_A19138VCCO_0 (+2.5V)
67FLASH_A18139LED_SCLK
68FLASH_A17140LED_GSCLK
69141
70SRAM_A17; FLASH_A16142CPLD_PIN_42
71DIAGNOSTIC_LED_ORANGE143CPLD_PIN_41
72DONE (Pullup to +2.5V)144JTAG_TDI
