Speed Signal measuring
A project log for JVC to Clio
I want to use a JVC car radio with Renault Clio's built-in steering wheel remote
nmeth-csabaNĂ©meth Csaba 11/24/2017 at 19:570 Comments
I measured values on pin A1 of the ISO 10487 connector.
Here you are the measured values:
Speed (km/h)Pulse duration (μs)
30~13000
40~10000
50~7700
70~5400
90~4200
100~3750
100~3400
120~3200
It can be calculated more accurate values with "distance = speed x time" formula. It seems the distance is around 0,105m. I this case the duration are the followings:
3012600
409450
507560
705400
904200
1003780
1103436
1203150
1402700
1502520
The arduino program for the measuring was the following:
ISO 10487 defines a standard for connectors for the head unit to the car's electrical system, consisting of a system of four different connectors typically used in head units for car audio.
   Power (A)
     | |1  |3  |5  |7  |
    _|                 |
   |_  |2  |4  |6  |8  |
   A1 Speed signal
   A2 Phone mute
   A3 Not connected
   A4 +12v battery
   A5 Antenna motor
   A6 Illumination
   A7 +12v switched
   A8 Ground
      +------|USB|------+
      |[ ]J1 +---+      |
      |( )TX0     RAW( )|  RAW
      |( )RXI     GND( )|  GND
 GND  |( )GND     RST( )|  RESET
 GND  |( )GND     VCC( )|  VCC
      |( )2        A3( )|
INT0  |( )3   /\   A2( )|
      |( )4  /  \  A1( )|
      |( )5  \  /  A0( )|
      |( )6   \/   15( )|  SCK
      |(X)7        14( )|  MISO
      |( )8        16( )|  MOSI
      |( )9        10( )|
           ProMicro
int SignalPin = 7;
unsigned long duration;
void setup()
  Serial.begin(9600);
  pinMode(SignalPin, INPUT_PULLUP);
void loop()
  duration = pulseIn(SignalPin, LOW);
  Serial.println(duration);
  delay(1000);
I forgot to mention that there was a 4N25 optocoupler on pin7. I will attach some pictures about my prototype board soon...
