Build Process Photos
A project log for Mountain Dulcimer
Another stringed instrument build
the-big-oneThe Big One 11/20/2017 at 15:060 Comments
Below is a (somewhat) chronological listing of photos I have taken throughout the build process, starting from the resawn, book-matched cherry for the top + back, all the way to the end.
Lots of pictures, click 'read more' to see them all.
Resawed the board to get bookmatched top / bottom
Installing kerfing
First part of fretboard inlays - the vines. Used veneer after cutting the fretboard with the scroll saw.
Gluing the headstock in place
Preparing the inlaid leaves. I first added veneer as the vein patterns on the leaves themselves, just like I did to make the vines on the fretboard.
After each leaf had veins on it, I inlaid each leaf onto the fretboard at the correct location.
Added fretboard binding
Reinforcing the sound holes
Gluing the top on. A bicycle inner tube cut about 1/4" wide makes for a very long elastic band.
Fretboard completed, with finish and hollow cut out
A couple of beauty shots
