• 2017-07-20
    Basile Laderchi07/20/2017 at 10:49 0 comments
    BasWheel v 2.00: Added tire_compatibility "rc1_10", added parameter rim_dxf, changed parameter names from dxf_filename to spoke_dxf and from spring_segments to spoke_segments, added spoke_type "Polaris_TerrainArmor"
    BasWheel v 2.01: Added spoke_type "Hankook_NPT"
    BasWheel v 2.02: Added spoke_type "segmented" and parameter spoke_angle. Fixed a bug with rim_type "barrel"
  • 2014-07-28
    Basile Laderchi08/08/2014 at 07:35 0 comments
    BasWheel v1.28: Added parameter rim_type
    Added a hole on the outer wheel to match the hole on the hub_type "screw"
  • 2014-06-20
    BasWheel v1.27: Added parameters hex_screw_spacer, hex_screw_OD, hex_screw_ID, hex_screwhole_depth, hub_magnet_count, hub_magnet_margin, hub_magnet_diameter and hub_magnet_height
  • 2014-06-04
    Basile Laderchi08/08/2014 at 07:34 0 comments
    BasWheel v1.26: Added hub_type "hex" and parameter hex_size
  • 2014-03-14
    Basile Laderchi03/14/2014 at 07:33 0 comments
    BasWheel v 1.25, 14 Mar 2014 : Added spoke_type "dxf" and parameter dxf_filename.
    Soon to follow a how-to tutorial for the spokes dxf generation.
  • 2014-03-07
    Basile Laderchi03/07/2014 at 07:03 0 comments
    BasWheel v1.24: added parameters tire_compatibility (either custom or pololu90 compatible tire) and flip_wheel (0: not flipped, 1: flipped)
