Parts needed
A project log for IRIS : another open source spectrometer
The idea is to build a not so expensive visible light spectrometer...
j0hnj0hn 08/25/2015 at 08:180 Comments
To be able to build the optical bench, I need :
- A slit ( http://www.babytronix.com/Slit-Mask.pdf ? )
- A software to be able to design the optical bench ( lensforge ? )
- Mechanical part to enclose the optical bench ( easy to do with a laser cutter and some plexiglas )
- a 40mmx10mm TEC to cool the CCD
- Mirror
- Gratings
