Going for the Jigsaw
A project log for Photobooth Control and Display
This project features Arduino compatible devices which connect to a PC and a camera
stefan-xpStefan-Xp 10/23/2014 at 20:1411 Comments
After a lot of deep thoughts i finaly got to the Solution to create my enclosure from Layers.
Perhapps I leave out the second plywood plate. I'm also afraid, that it will take me another week to get on the jigsaw.
Stefan-Xp wrote 10/27/2014 at 19:06 point
Another advantage of plywood is, that its really cheap against acrylics :-D
davedarko wrote 10/23/2014 at 21:32 point
Some hardware stores or better "Baumaerkte" are cutting their wood to a certain size for free, but I guess you need more than that? I need a laser cutter :D My fixietube clock definitely needs a lasercut case!
Stefan-Xp wrote 10/23/2014 at 21:45 point
The final Size of the plywood is already ok.
I need a lasercutter too :-D But manual labor is much cheaper ;)
I have to saw some holes for the connectors.
Drilled only looks really bad.
To bad the Cutworks company only cuts metal ;-)
davedarko wrote 10/23/2014 at 22:05 point
A year ago I was working in a copy shop and when I left they acquired a laser cutter... bad timing :D I hope they will cut my case, not sure if it is already in use for customers though. I want to make it look like my printrbot simple, so it is essential. Drilling holes by hand for a LED matrix is a pain... and I'll never get them perfect.
Stefan-Xp wrote 10/23/2014 at 22:13 point
I'm not sure but i thought for your fixietube clock there are only 6 drillings?
With the right tools it shouldn't be a difficult task...
davedarko wrote 10/23/2014 at 22:51 point
hm. well. I may be able to use a jigsaw for that as well, especially when stubby the hexapod is cut out by hand...
Stefan-Xp wrote 10/24/2014 at 16:08 point
Okay, it looks a bit more Difficult ;-)
A really elaborate Design, against that my designs are really simple :-D
davedarko wrote 10/24/2014 at 17:31 point
It could have been simpler but I always end up trying to perfect things :D
Stefan-Xp wrote 10/26/2014 at 21:05 point
*Thumb up* Which kind of Material are you going to use?
davedarko wrote 10/26/2014 at 23:28 point
regular 4mm plywood from the hardware store. Mainly because I don't like the look of blank acrylic sheets. Although I could settle for black acrylics. Hmm. But I like wood. I may use some wood stain to darken it a bit.
