cheap way to add height
A project log for Stickvise - low profile soldering vise
Stickvise is a low profile vise designed for PCB soldering. This product was born on Hackaday.io.
alex-richAlex Rich 11/29/2014 at 00:160 Comments
Just had a good idea, instead of custom tall jaw plates, the standard jaw plates can easily be raised using #4 spacers. Depending on how tall the spacer is, you may also need longer #4-40 screws. Both easily found at the hardware store, but could potentially be a cheap add-on to ship with the vise.
