Feeder configuration
A project log for SMT50 pick-and-place
Describes my experiences buying, setting up, and using the SMT50 pick and place machine
tim-wilkinsonTim Wilkinson 11/22/2014 at 03:021 Comment
The basic machine comes with a west feeder consisting of 20 8mm feeders. I added an additional north feeder which comes with an assortment of 8mm, 12mm and 16mm feeders (I like to have options!). I'd watched the videos and, looking at the machine head, I could see the pointer head which was used for dragging the tapes through the feeders. But how does the machine know where the feeders are?
On the top bar of the app you'll find a button "Feeders" (or you will if you're using my translations). Pressing that opens up the feeder pane. This one shows many feeders already configured:
As I recall, the default project which comes with the machine only defines two of the 36 available feeders; the rest you have to define by hand! This isn't that hard to do once you've worked out how to move the machine head around and have the MARK camera working. However, it is rather tedious. As a starting point I've added my feeder configurations to the GitHub repo. These are part of the project database and you can find if here https://github.com/aanon4/SMT50/blob/master/OURSMT/config/Project_smt.cfg. When it comes time to use an actual feeder for components, you'll probably need to tweak the values a little depending on the tape properties, component size, etc. To do this simply right click on the feeder line and select "Modify feeder" from the popup menu.
Feeders are number 1-20 north-west to south-west, and 21-36 north-east to north-west. This isn't that sensible really, but it fitted with the numbering scheme of the two originally defined feeders and, at the time, I thought the numbering might be significant. It isn't, and you can number them anything you want.
Modifying feeders
The feeder modification popup looks like this:
There are lots of things happening in this window and, as I write this, I don't know what all of them are for. In the context of just feeding the component, the X, Y, feeding method and tape & location settings are most important. The X,Y set the exact position of the pick nozzle over the component and should be as central as possible. The feeder method and tape & location settings together define how the tape of components is handled (i.e. how the tape is advanced to the next component). All feeders on the SMT50 use the "Pull" method. Tape and location is defined in another settings window which we'll talk about next.
fikret duru wrote 02/02/2019 at 21:33 point
dear friend please oursmt software send to me. i have oursmt. but my oursmt bad english launguge and config. please fikretduru@gmail.com send. thank you
