Heat dissipation test
A project log for Fan controller for Re:Load Pro
ATtiny microcontroller fan controller, with configurable control variables over the USB interface.
runeRune 11/22/2014 at 17:060 Comments
This is a little test to see how good the heat dissipation is with the new fan installed. The test was run for 10 minutes without any overtemp protection warnings.
As you can see, it is able to dissipates 60W.
