Code update
A project log for Hakko 907 based Soldering Station
A soldering station based on the easy to source Hakko 907 soldering iron, which is a 24V 50W soldering iron with integrated thermistor.
kuroKuro 05/02/2015 at 06:464 Comments
I've updated the code in the soldering station files. There's new content and an attempt to fix a problem with the PID controlling the temperature around 10C above the setpoint.
Other features:
  1. Auto turn-off with default time set to 45 minutes;
  2. If you reburn the frimware, it will use the Kp, Ki and Kd defined in the code instead of trying to load them from EEPROM, unless you run the autotune. This makes it possible to use the soldering station without autotuning.
That's it.
Marcel wrote 09/26/2016 at 20:08 point
Hi, The link to download the project files is not working. Please update files.
Thanks
Kuro wrote 09/26/2016 at 20:31 point
The link to the GitHub is working alright here.
aratansi wrote 08/02/2016 at 03:38 point
Hi
This is a great project. The link to download the project files is not working. can you please update/ fix the link.
thanks
Kuro wrote 08/02/2016 at 11:22 point
I've reuploaded the files. Try downloading again.
When I have the time I'll check if anything is still broken after the wipe on the VPS.
