Preparing for production test
A project log for Open Source HW: Xilinx ZYNQ7000 System on Module
75x40 mm, 6 layer PCB, Xilinx XC7Z7010 FPGA, dual core ARM Cortex-A9, 32Mbyte Flash, SD, microSD, Bluetooth, 100 mil headers, single 3.3V
antti-lukatsAntti Lukats 11/27/2014 at 20:430 Comments
Board testing is often overlooked at the design stage, so was it with the first version of the PCB's..
Ingun visiting us, OzOM-A PCB rev 1 on the demo fixture.
This how the fixture looks like, really smooth movement and really easy to change the top and bottom parts of the replaceable fixtures.
And important to know: minimal recommended test-point is 0.8mm! So rev 2 gets 0.8 mm TP's one the bottom side, test points on both sides are possible too, but better not!
