New Beginnings
A project log for Distance Analyzer 3000
Measuring device housed in an Altoids tin. Uses a rotary encoder with a wheel to estimate distance and display measurements on an LCD.
john-hamannJohn Hamann 01/19/2015 at 01:060 Comments
So because of my lack of spacial planning and poor organization, the first iteration of the device doesn't close all the way and some of the contacts aren't as sound as I would like them to be. I'm planning on building the Distance Analyzer 5000 which will have more spacial planning and 2 dedicated interrupt pins for the encoder. Also I will be laser cutting the measuring wheel for increased accuracy.
I'll be using a Arduino mini clone with the ATMEGA-328p, as well as an i2c backpack on the LCD to reduce the wire clutter. Other than that not much else is going to change.
