Driving the coil directly
A project log for Web powered antique wind gauge
An antique volt meter paired with a Raspberry Pi to display real time wind data.
mechanicalsquidmechanicalsquid 11/26/2014 at 11:080 Comments
A quick trip down to my local hackerspace (SoMakeIt) to strip it and try driving the coil directly.
Turns out, it needs 48VDC directly to the coil to get full deflection on the gauge. It also consumes about 5W. It will of course consume this continuously to maintain the needle deflection.
While it's possible to drive this, it's not a simple solution, and I don't like the idea of chewing through 5W continuously.
I'm going to try stripping out the innards and using a servo motor for movement instead.
