MILESTONE: Flight-Version Prototype
A project log for Square Inch To Space
Send your own hardware to space
paul-kocylaPaul Kocyla 02/16/2015 at 10:416 Comments
Chipstar prototype soldered.
That´s the (semi)final version of the actual chipstar board in the flight version.
Some small modifications may be made depending if we´ll deploy of a CubeSat or a PocketQub.
vcazan wrote 02/26/2015 at 17:03 point
This is a great, when do you think you will have these ready to play with?
Paul Kocyla wrote 02/26/2015 at 21:33 point
The first series board (8 pieces on one PCB) is already in production.
I´ll do a partplacing with stencil first - if everything goes well, then it can go into the placing machine. Shoud be a matter of a few weeks.
Austin Marandos wrote 02/17/2015 at 03:05 point
Awesome, I'm thinking of setting up a SatNogs ground stations I'm located in Australia, so i may be able to help you with communication with the satellite.
Paul Kocyla wrote 02/17/2015 at 09:38 point
Cool. The SatNogs should be good to get the signal.
Austin Marandos wrote 02/16/2015 at 21:49 point
looks great
Paul Kocyla wrote 02/16/2015 at 21:58 point
Thanx :) I´ll make a balloon test soon. I´ll be away for vacation for one week, but then I´ll prepare a helium balloon to test the TX power. Calculations are ok, but the reality is kinda different, so it is better to find out how the system behaves in reality.
