Hardware Revision 3
A project log for L-Star: Software-Defined 6502 Computer
Replicate an Apple-1. Or an OSI Challenger. Or something else. Design your own 6502 computer by programming it.
jac-goudsmitJac Goudsmit 06/15/2016 at 03:272 Comments
As I mentioned in the "Hardware Revision 2" posting, there were some small but significant problems with that version of the schematic and PCB:
Here's a picture of the Revision 3 layout:
First of all, I switched the location of A16 and ~RAMEN (and the accompanying 3.3V and GND pins) so that ~RAMEN can be jumpered to P27 which is connected to KBCLK in the "default" configuration. I considered moving things around so that ~RAMEN would be the default for P27 and KBCLK would be an alternative, but I decided it would cause too much confusion so I didn't do that.
I moved the power LED to a location between the pushbutton switches, so now there should be enough space for a finger to push the button again. I also lined the pushbuttons up, close to the places where they were in revision 1. The LED is in a sort-of-odd place, so far away from the power connector and the power switch, but it's where there was enough space for the traces. I would have liked it on the right side of the board (and the power switch too) because I imagine that side will be pointing towards the user, but that's simply impossible unless I make the board a lot bigger.
I edited all the footprints on the board and made sure that they all use solder islands with a size that's big enough to solder if you have a non-professional solder iron, or if (like me) you have some old solder tin that doesn't flow as well as it used to do.
I discovered another oversight that I wanted to fix: the jumpers didn't have the ~RESET6502 signal on them. So I changed the jumper block from 7-by-5 to 8-by-5 and added the signal near the top, where it was easy to line up with the ~RES6502 pin on the expansion port connector. As it turns out, this had a fortunate side-effect: I found out that five 10-pin pin headers are cheaper than two 20-pin headers of the same series (the ones with the green plastic that I got by mistake but look really good and nicely define the color scheme of the project, along with the purple PCB and the red jumpers). This will make it easier to break/cut the jumpers to size for the final kit.
I also made the footprint of the voltage regulators a little smaller, which allowed me to reduce the board size again, and to line up the power switch with the RESET6502 pushbutton.
I haven't ordered parts or PCB's yet, because I'm considering another change: I'm thinking of putting the voltage regulators upright, and wiring them up differently so they'll be in parallel instead of in series. This will allow expansion boards to use more power on the 5V rail (the 3.3V regulator is currently fed by the 5V rail) and might reduce heat production because the current only has to go through one regulator instead of two. On the other hand, it might cause other problems like interference and the need for bigger electrolytic capacitors.
Another change I'm considering is to use a 50-pin expansion header instead of a 40-pin one. You may have noticed that there is just enough space to do that, and that's not a coincidence. A 50-pin header would make it possible to run the video and keyboard connectors to the expansion board, as well as some signals (~BE, A16, ~RAMEN) that I had to leave out because of the 40-pin limit. This would make it possible to design an expansion board that e.g. generates color video and uses the PS/2 keyboard, without the need to add connectors for them to the expansion board. And it would be possible to let an expansion board take over some functions take over some functions that currently only the Propeller on the L-Star board can do, such as controlling the SRAM chip. Furthermore, it lets me add some more pins to supply power to the expansion board, which is also a little bit of a concern.
Brett wrote 07/26/2016 at 21:29 point
Hi, Is the revision 3 version PCB orderable? Or the kit orderable? Or is rev. 4 right around the corner? I have my old breadboard version sitting in the office. It looks cool but it would be neat to shrink it all into one of these PCBs for a clean look.
Also, do you think a small speaker could be connecter via jumper wire (like the old PC speakers) to the expansion port and triggered in 6502 ASM to create sounds?
-Brett
Jac Goudsmit wrote 07/28/2016 at 04:33 point
Hi Brett! At this time (end of July 2016), nothing is orderable yet, at least not from me.
I haven't built a Revision 3 PCB to test it myself yet, but it should work in the current state that's stored in Github at
https://raw.githubusercontent.com/jacgoudsmit/L-Star/c15c1d2912c68b2ae662c43d3d3ce162654cd081/Hardware/Kicad/L-StarPlus/L-Star.kicad_pcb
As for connecting a speaker, yeah that should probably work. Probably the safest is to connect it between 3.3V and one of the Propeller pins P25, P26 or P27. And obviously write some firmware on the Propeller to let the 6502 control the speaker.
