Assembler and Emulator Source Now Public
A project log for Trinity
A ternary LISP machine
john-sullyJohn Sully 12/19/2014 at 06:280 Comments
I uploaded the assembler and emulator source code to github. Try it out and let me know if it works for you. I omitted a build script as its only one .cpp file for each. The code was written and tested on windows, but as a simple console app it should work on any platform with little modification.
Try it out: https://github.com/JohnSully/Trinity
A disclaimer on the code: I wrote this quickly over the weekend and hacked it mercilsy to try new stuff. Its not the cleanest code but it works.
I also took some time to modify the jump instructions. JAF has now been replaced with JEQ, JEZ, and JMP. The new "ABC" program is much simpler:
; Outputs A,B,...,Z in a continuous loop
;Setup
Start:
    LIM    '@'    ; 'A'-1
Loop:    SWP
    LIM    1
    ADD
    OUT
;Check if done
    SWP
    LIM    'Z'
    SWP
    JEQ    Done
    JMP Loop
Done:
    JMP Start
And assembled:
000000: 00+--+ 0+-+0+     ;LIM 0+-+0+
0000+-: 00+--0     ;SWP
0000+0: 00+--+ 00000+     ;LIM 00000+
000+--: 0000+-     ;ADD
000+-0: 00+-00     ;OUT
000+-+: 00+--0     ;SWP
000+0-: 00+--+ 0+0+00     ;LIM 0+0+00
000+0+: 00+--0     ;SWP
000++-: 000+-- 0000+-     ;JEQ Done[0]:(0000+-)
000+++: 000+-+ 000---     ;JMP Loop[0]:(000---)
00+--0: 000+-+ 00-+0+     ;JMP Start[0]:(00-+0+)
