software - Part 1
A project log for Car of the future!
An ongoing project to add entertainment, bells, whistles and quality of life improvements to the car.
jdubjDub 12/18/2014 at 04:080 Comments
The software.....
Huge shout out to Whufcle
his post at http://totalxbmc.tv/new-forum/index.php?topic=137.0 was what I used as a starting point
the gist is this, the sd card is formatted as fat32, and has all the normal pi files on it, and additionally the SYSTEM file for openelec, the USB stick is formatted ext4 as is mounted as /storage
the nice thing here where most people goof up is they use references to SDA or SDB and if you have another USB stick plugged in, you may not end up booting correctly, in cmdline.txt we are setting it to mount the partitions by LABEL
So its not perfect still, if you plug in a USB drive with the label SYSTEM or STORAGE things may go bad, so lets just not do that mmmkay?
Out of the box update all your addons, grab a skin to use, I prefer xTV for the kids
we are 80% there, now we just need to....
1.) enable lirc_rpi
2.) get the SNES controller working
3.) be able to autoresume what was being played before power was cut
4.) turn on the monitor on bootup
5.) add games
6.) more... cool stuff?
