Well Water Tank monitoring BLOG
A project log for well water monitor and performance meter
A system for household water well and tanks that will monitor not just water level but also well performance and alert on water leaks.
abraxas1abraxas1 03/02/2015 at 15:260 Comments
monitor water level with ultrasonic system to better than 1/2" allows for calculating water usage and also water leakage with sufficient accuracy.
system could also shut down tank outlet if major leak determined. would also have to shut down pressure pump...
system would report usage data and alarm status through webpage interface, phone app, etc.
