USB DAC with amplifier
A USB DAC with a 3-W x 2 amplifier
This is a prototype for a USB DAC with an amplifier. When plugged into a USB port the OS recognizes it as a USB sound card and no installation of drivers is need. The amplifier is capable of driving two 3 W, 8 Ohm speakers.
A SPI interface can be used to control playback on the connected computer.
USB Interface
The USB interface is all done by the PCM2705 IC. When the DAC is connected to a computer it recognizes it as a USB sound card and no manual installation of drivers is need. The DAC can control playback on the computer with the following HID-states:
  • Mute
  • Volume up
  • Volume down
  • Play/Pause
  • Stop
  • Previous
  • Next
DAC
The DAC used is the one integrated into the PCM2705, it is a 16-Bit Delta-Sigma Stereo DAC with a SNR at 98 dB. Many similar boards use an external DAC for better performance but since small size and cost is more importent in this project i choose the integrated DAC.
Amplifier
The amplifier used for this project is TPA2008D2 from TI. It is a 3-W Stereo Class-D amp.
SPI interface
PCM2705 has a SPI interface that can be used to set the HID-states. I wrote a small Arduino library so playback can easily be controlled from an Arduino.
  • 1 × PCM2075 Stereo USB DAC with line-out
  • 1 × TPA2008D2 3-W stereo class-D audio amplifier
  • 1 × Crystal 12.000 MHz HC-49/S 30 pF
  • 1 × Resistor, 1MOhm 5% Metal film
  • 2 × Capacitor, 15pF 10% Ceramic
View all 21 components
  • Android and USB DAC
    Andreas Dahlberg01/06/2015 at 21:52 0 comments
    Found out today that support for USB audio peripherals was added in Android Lollipop. Tested the USB DAC with my Nexus 5 and it worked perfectly! The only downside is that a external power supply is needed when volume is increased.
    Android USB Audio
  • New DAC/AMP is done!
    Andreas Dahlberg04/14/2014 at 15:19 0 comments
    I just finished soldering the components on the latest PCB. Did some testing and everything seems to work. Had some problems with the volume at first, it would change randomly when i got close to the PCB. I think a bad ground connection caused this. The USB-cable i used was very loose in the connector and when i changed the cable everything was fine.
  • Components and PCB arrived!
    Andreas Dahlberg04/07/2014 at 16:33 0 comments
    Got the new PCB and some missing components for the new version today! Unfortunately i could only solder the USB connector before my almost new solder station broke, so now i must get a replacement before i can continue.
    Here is the new PCB compared to the old one.
  • PCB ordered
    Andreas Dahlberg03/24/2014 at 12:05 0 comments
    The PCBs are now ordered from OSH park :)
  • New PCB layout
    Andreas Dahlberg03/20/2014 at 13:20 0 comments
    The new PCB layout is soon ready :) Only some routing and adjustments left
  • Updated schematic
    Andreas Dahlberg03/15/2014 at 16:57 0 comments
    I am almost done with the new schematic for the (hopefully) final version. The only thing left before i start with the PCB layout is to check all footprints and recheck all connections.
View all 6 project logs
Anthony wrote 04/13/2017 at 02:38 point
Did you hand solder the thermal pad on the amp? If so, how did you go about it?
Andreas Dahlberg wrote 04/18/2017 at 19:28 point
Yes i did. It does not show in the pictures but the thermal pad is also exposed on the bottom side of the PCB. So i put some solder on the top side pad, put the IC on and applied heat on the bottom side.
Eric Evenchick wrote 04/07/2014 at 20:31 point
Neat, the PCM2705C looks like a really cool part... all in one USB DAC that just works with Windows.
Any chance you could put a PDF of the schematics in the Github repo? It'd be nice to see them without needing a CAD tool. Thanks!
Andreas Dahlberg wrote 04/08/2014 at 08:09 point
Yes, really nice that no special drivers is needed. I just uploaded the schematics to the Github repo as a PNG file, hope it works!
Eric Evenchick wrote 04/08/2014 at 17:50 point
Awesome, thanks! It's actually not too many components. Nice to see a mostly through hole design for this.
AVR wrote 03/27/2014 at 02:04 point
This is pretty cool! I'm thinking about making something similar when I'm done with my current projects. I'm working on an audio board right now that I might be able to use to make a USB DAC like this minus the amp though.
