--- STATE ---
A project log for commonCode (not exclusively for AVRs)
A shit-ton of things that are useful for a shit-ton of projects. (and, Think 'apt-get' for reusable project-code)
eric-hertzEric Hertz 02/25/2017 at 16:310 Comments
To be honest, I ran out
of steam on making this project "public-ready." But most of my projects
rely on it, so it's "out there." At least, in parts.
I doubt
that commonCode would offer much, library-wise, that you couldn't
find elsewhere.
So, I guess, upon re-looking at commonCode from an outside-level (vs. just using it for my own projects), it might be less about the libraries themselves, and more something along the lines of an *environment* like Arduino; plausibly a bit more customizable and more optimizable, but significantly (nearly infinitely) less-documented and less-supported... nevermind more fine-tuned for my own needs/habits/style... more esoteric ;)
There'd definitely be a learning-curve to use this system or any of the code within it, probably starting with 'blinky' (or 'heartBeat') and slowly moving up from there. And, again, since I've put public-readiness on the back-burner, the examples stop pretty early-on, pretty much immediately after the [bitbanged] UART 'echo' example. From there, (nearly everything else) user-level documentation is sparse, and user-level consistency even more-so.
Oh, and... I went through several different iterations of "public-readying" those early-examples, especially as I started making it even more architecture-independent, so the actual user-level interface/examples probably vary between each "step"...
Weee!
So, again, *I* use this 'system' for nearly every code-based project I do... and improve it as I go along... But it's not really "public-ready," and making it so, in its entirety, would be a tremendous undertaking.
But if you're *really* interested in trying out the [a bit outdated] blinky example...
https://github.com/esot-eric-test/heartbeat-2.00-gitHubbing_-revisions
And here's a project which uses 'the system':
https://github.com/ericwazhung/sdramThingZero
Browse into the _commonCode_localized directory to see what's used in that project... Usually I start a project with nothing more than 'heartBeat', then move on to 'polled_uat', and then 'polled_uar'. These *should* have test-code in a subdirectory... e.g. _commonCode_localized/heartbeat/2.06/<test>/ wherein you should be able to type 'make' and try it out... But no promises. ;)
Thanks @David H Haffner Sr for inspiring this status-update!
