prerendered menu sketch
A project log for FreEader - minimal e-book reader
HTML/EPUB <pandoc> LATEX <dvipng> png <imagemagick> pbm <pbmtojbg85> SD-Card <uC> 4.4" E-Ink
ventosusventosus 09/13/2015 at 19:300 Comments
Althoug freeader should be a minimal reader, there must be some way to navigate between books, e.g. a kind of menu structure.
This menu structure will also be prerendered pixel data, like the books themselves.
I use Edje from the Enlightenment Foundation Libraries (EFL) as underlying theming and layouting engine.
https://docs.enlightenment.org/auto/eio/edje_main.html
https://docs.enlightenment.org/auto/edje/edcref.html
Why Edje? I have built other things on top of the EFL, know them well and like them a lot.
https://github.com/ventosus/edje2yuv
https://openmusickontrollers.github.io/lv2/synthpod/
With Evas (the EFL canvas library) you can draw to pretty much everying (X11, openGL, Wayland, framebuffer, pixel buffer, ...). Here I draw to a pixel buffer and then compress it with JBIG1.
By using Edje, the menu structure can be themed to the last nut. I've experimented a bit and below you can see two screenshots of a sketch of a simple menu theme.
The menu structure will have limited capabilities, e.g. navigating a directory tree and loading a given book.
I have just uploaded my repository with the current toolchain.
https://github.com/ventosus/freeader
