• New laser!
    attah04/07/2015 at 19:26 0 comments
    The old laser decided to vanish in the mail, so I got a new one. Works great!
    Now on to making motor mounts in acrylic and tinkering with the smoke extraction.
    I switched g-code generator to DXF2GCODE so I had to adjust the program a bit, but it was well worth it since it produces much nicer shapes than the InkScape plugin i used previously.
