General project update
A project log for PIC MCUs Based Homebrew Computer
The goal: to make a working computer, with a keyboard input, LCD Display output, a compiler and to have fun all the way. NEWBIE ALERT
davedave 02/11/2015 at 23:482 Comments
Hello, dear hackaday!
I've had a lot of problems with my project, actually with my data transfer protocol. It was not the problom with the protocol itself, but something was causing it to not work properly. With help of another hackada member, I managed to solve the problem. It was a data cable problem. The only thing that was also in common with the SRAM module and not with any other module. Hmm, maybe I should give my SRAM another try. So, I would like to thank esot.eric.wazhung for all the help and tips that lead me to solution.
I demonstrate my project in the video bellow.
And always remember:
Tomorrow, I will let you know what are my next goals for my project.
dave wrote 02/12/2015 at 12:09 point
Thank you for your comment! :) You deserved the shout-out ! I really must try that with SRAM yeah. And I will, but I need to get some components.
Eric Hertz wrote 02/12/2015 at 10:06 point
Hah! Thanks for the shout-out, David!
But, seriously, all I did was throw out a few random ideas.... I threw noise at you. You picked out the right solution from that noise.
Careful twisting those replacement wires!
Ribbon cable has its place... just ground every-other wire, and you might even get better noise-immunity than your new wiring.
Also, major props on this undertaking. That's a *lot* of wires and chips and peripherals, and a unique new protocol. Nicely-done. Hope it works out with the SRAM!
