Initial pump testing
A project log for Budget BarBot
A BarBot for dispensing cocktails (on a budget)
david-hopkinsDavid Hopkins 01/29/2015 at 09:530 Comments
Testing of this:
Specs are 6V, flow rate (found out after testing) is 60ml/min
this is far too slow, and inaccurate, real flow is more like 45ml/min, this means it would take over a minute to pour a cocktail (one pump per reagent), or over 30 seconds if the smallest measure is 25ml.
this is not acceptable, another solution must be found!
Concept as first envisaged:
