Prototype Clamp Created!
A project log for Budget BarBot
A BarBot for dispensing cocktails (on a budget)
david-hopkinsDavid Hopkins 01/29/2015 at 10:211 Comment
Knocked this up last night from plasticard and spare bits
servo is a HK15138 3.8Kg-cm servo from hobbyking (£2.22)
calculated exerting 5.4Kg at start of travel building to technically infinite at end of travel, either way, plenty of force to clamp the tube properly. bolts used for easy adjustment.
Dillon Nichols wrote 08/24/2016 at 12:48 point
This is an interesting idea. We're using solinoid valves that are about the same price for our project. http://www.ebay.com/itm/1-4-NPT-Electric-Solenoid-Valve-12-Volt-DC-12VDC-N-C-RO-Air-WaterBBTF-12pk-/272050889127?hash=item3f577f21a7
