Testing the drill template and pipework layout
A project log for Budget BarBot
A BarBot for dispensing cocktails (on a budget)
david-hopkinsDavid Hopkins 02/16/2015 at 10:470 Comments
will need some fine tuning but the spacing works out well, toying with the idea of using different leds underneath the T joints to illuminate the plastic connectors, but not sure. may just have a L connector on the end instead of capping it off, will def be neater.
