The circuit prototypes work.
A project log for Smart Switch
A 125 volt 15 amp dimmer switch with built-in 5 volt power supply, current monitoring, and programmable micro-controller.
karl-edlerKarl Edler 02/09/2015 at 04:450 Comments
The circuit prototypes work. I can get 5V off the AC to power the micro-controller and the switch throttles my electric drill just fine. It throttles a florescent lamp too, but it seems that florescent lamps do not like to be throttled. The bulb burned out. The hall sensor can see the current draw.
