Mood lighting UI
A project log for Voice controlled connected home
This project aims to bind all IoT devices together in a single unified voice controlled interface.
anand-tamariyaAnand Tamariya 07/29/2015 at 15:190 Comments
Now that mood lighting works with command line, the obvious next step is to add this capability in android app. I'm thinking of a color palette that the user can use to select a color of his choice. After all, there are a range of colors in between red, green and blue.
