Split T/R for Higher Power
A project log for Open Ground Penetrating Radar
Make the invisible visible for about $500.
glenn-powersGlenn Powers 02/28/2015 at 19:140 Comments
For surveys at greater depths, it is possible to use a separate high power transmitter with a separate antenna. However, I think I a lower power T/R switch on the recieving side would still needed to prevent the RF detector from becoming saturated by the initial transmission.
