Bi-color LED Matrix Flappy Bird Game
This is a hand-held Flappy Bird game built using the Bi-color LED Matrix Driver Module Kit from jolliFactory
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Flappy Bird is one of the more recent popular games around which is created by Dong Nguyen. It is a simple one-button game in which you have to navigate the flapping bird past obstacles.
One of the electronics DIY kit jolliFactory came up with is the Bi-color LED Matrix Driver Module Kit. This module is designed to be chain-able so that you may daisy-chain the modules together to the number of modules you need to suit your project.
For this project, we will build a simple Arduino based Bi-color LED Matrix Flappy game here using the Bi-color LED Matrix Driver Module Kits.
To build this project, basic electronics knowledge with electronics component soldering skill and some knowledge on using the Arduino are required.
Full detail on building this project can be found at http://www.instructables.com/id/Arduino-based-Bi-color-LED-Matrix-Flappy-Bird-Game/
Video: http://youtu.be/4E5S8fVsneo
