NaHCO3 Raw Readings
A project log for Isothermal Calorimeter
This project is a Heat Conduction Isothermal Calorimeter based on the designs of Dr Lars Wadsö, Sweden.
ahmed-hefnawi-voltaAhmed Hefnawi (Volta) 04/18/2015 at 20:040 Comments
I added some NaHCO3 with water (exothermic reaction) into the sample vial and the reference vial contained sand at that time.
The following is a plot of the raw calorimeter readings in micro-Volts versus the time in seconds, the plot was created in Python using matplotlib.
I thought I should add the thermal power after conversion as well in milli-Watts,
