It lives-ish!
A project log for Intel Edison: USB Storage Sled
Prototype design of a USB Storage Sled for use with the Intel Edison IoT module. Implements SATA & PATA.
zittwarezittware 05/07/2015 at 05:250 Comments
It's been a while; but I have been debugging the design as time permits. Upon initial assembly using a hotskillet reflow in the garage; I had some issues with the Edison high-density connectors. After getting that sorted; the USB hub and PATA chip identified themselves to my netbook. putting a USB memory stick on the DD[4] interface of the hub showed that I could read/write the USB bus.
The USB hub is seen by the Edison in "host mode" and by J16 (host computer) in device mode. I can download Arduino sketches via J16 when in device mode.
Initial debug showed several issues.
1) the PL2571B USB->SATA chip wasn't being seen on the USB hub. Later tracked down to a bad solder joint on the clock generator's RE17 22ohm series resistor. After fixing that; the SATA interface shows up as USB Mass Storage. I do not currently have my SSD available at my home work bench; so will retrieve it from the initial test bed tomorrow.
2) the Cypress AT2LP (USB->PATA) chip is being seen on the usb bus; but because I didn't wire in an EEPROM. :(
3) U36 was the wrong package; so I can't power J16 when in host mode.
4) The U5/UE6/UE7 eeprom connections don't work because there doesn't appear to be enough bandwidth in UE6 - a risk I took in the initial design; but in retrospect was flawed to begin with.
5) J3 - the FTDI USB debug interface to the Edison kernel had some solderablity issues around J3 - I think due to close proximity to un-tented vias near the pins of J3. Was able to workaround the issue using some detail soldering - but will need to be fixed in the final design with tenting of vias - and possibly moving some of them.
I'm going to try and find the right package for U36 and more importantly figure out how to dead-bug rework a EEPROM to the AT2LP to see if I can get that interface online in the near future.
The other thing which needs to be done; but is likely beyond my home workbench capabilities is to do a USB dataeye analysis to see if there is any margin in the design.
