1/8 buggies
A project log for Ultimate running aid
Eliminate everything from running but the running part.
lion-mclionheadlion mclionhead 02/23/2018 at 03:460 Comments
Burned 3926mAh going 6.45 miles, or 608mAh/mile.  The camera system with HS-311 made it as bad as a brushed motor.  Using P200, D1000, it was stable enough to be useful, at 9min/mile.  Any faster & the oscillations grew.  It burns through tires & servos at all speeds.
So the H-King Sandstorm was a very robust solution & buggies don't require as draconian modifications as the Lunchbox.  The buggy has been the winner, despite monster trucks intuitively having more payload capacity.  Trucks are about as unstable as buggies.
Buggies need clearance for the tires, so they're leaning towards a very long design with payload bay between the tires.
All the hobbyking models are of course, out of stock.  The prices of what really exists are more than full sized cars, when servos, batteries, & motors are considered.  Hobbyking has a loose definition of scale.
Having built up 5 vehicles now, the thrill of building is gone.  It's more interesting to solve problems with software.
H-King Rattler ARR   18"x10.6"x5.9"   $152
Narrower than the lunchbox.  out of stock
BSR Berserker 1/8 Electric Truggy Updated (ARR) 20"x16"x8"  $400
Too big
Basher SaberTooth 1/8 Scale Truggy (ARR) 23"x17"x8.5" $220
Too big
Quanum Vandal 1/10 4WD Electric Racing Buggy (ARR)  16"x10"x5.5" $101
out of stock
Trooper Pro Edition 4x4 1/10 Brushless SCT (ARR)    21.6"x12.2"x7.5" $208
Definite contender.  The payload bay could go between the tires & ride below the tires.  Motor is in the middle.
Turnigy Trooper SCT 4x4 1/10 Brushless Short Course Truck (ARR) 21.6"x12.2"x7.5" $160
Out of stock.  Plastic version of the pro.
Team Associated 1/8 RC8.2e 4WD Buggy 18.5" x12"x4.4" $500
More than a full sized car.
The lunchbox 12.5"x11"x5"
H-king sandstorm (tested) 14"x8.5"x4.5" $110
16"x5" payload
Tamiya 1/10 Top Force 2017 4WD Buggy Kit (out of stock) 15.7"x9.8"x7.4" $194
Too narrow
Losi 1/8 8IGHT-E 4WD Buggy 19.6"x10.2"x7.1" $500
