First test
A project log for micro generator
In theory it is simple: a magnet moves inside a coil and generates voltage by induction.
jay-tjay-t 04/04/2015 at 03:480 Comments
I winded a coil on a biro tube. The coil is about a meter wire. I get 0.7 volts measured with my oscilloscope using a 8 x 10 mm neodym magnet inside.
I have to find a tube which has an inner width of about 9 mm and wind a more thicker coil around it to get more volts.
